looking to install intermitant wipers on my 96 tercel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2010, 05:12 PM   #1 (permalink)
View 96 TERCEL's Photo Gallery
Hi all I found a 95 tercel at a local junk yard that has intermitant wipers.I'd like to add the intermittant wipers to my 96 tercel,But before I go back to the junkyard I wanted to ask here in the forum IF ? the swap can be done and if so What should I take off from the donor car at the junk yard THANKS in advance
96 TERCEL is offline   Reply With Quote
Old 06-30-2010, 06:29 AM   #2 (permalink)
... It still runs...
View bkftl's Photo Gallery
What a heck is a pulse whipper? i never heard of that!
How does it differ from a regular whipper?
Are you just changing the blade, or actual whipper ARMS?
If ur gonna change the whipper BLADE, u can simply go to autozone or walmart to buy NEW whiper blades, I would NOT get them off a junk car because the rubber gets damaged over time, that will be money wasted. There are realy good whipers avalible, i cannot afford em but i hear they are quite good, there are RAIN-X ones, look kinda cool too. 27$ each or so, last time i saw.
If you are gonna change the whole arms u need to get the arm and the little screw, first id check that the whiper arm will fit instead of ur old one onto the bolt.
You might be talking about whipers that both come out of the middle and then one goes ONE way and one goes another way? for that kind of MOD, u need to get the whole system off the junk car, u will need whiper arms, and whatever makes em move, i think its a set of gears below the whipers, or a few levers. you might be able to reuse your motor but it might have a different gearbox.
Goodluck
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 06-30-2010, 06:54 AM   #3 (permalink)
pulse is a another word for intermittant wipers.Im looking to put intermitant wipers in my car if I can.I find it a pain in a light rain to either continue to hit the mist lever or turn the wiper switch to low and the wipers rub because its not raining hard enough. THANKS
Old 06-30-2010, 08:18 AM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
The wiper switch behind the wheel is what you need. Most people change the whole piece including the turn switch.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-30-2010, 08:21 AM   #5 (permalink)
OK thanks for the info
