Strange Vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2010, 01:51 PM   #1 (permalink)
... It still runs...
View bkftl's Photo Gallery
Strange Vibration
Hi, i have a strange vibration from the engine
What i know is:
I have a exhaust gasket leak, smoke comes out but the car drove fine without it before.
Vibration is NOT a misfire, all cylinders work fine.
Its seems to be not from the CLUTCH or TRANSMISSION 4 speed manual
Right after engine start, car sounds ok, and has a low vibration, if the RPM increased vibration increases. once RPM hits medium to high - vibration goes away car sounds normal?
Is that just the fucking gasket or what? What do u think?
Thanks again for views and replies!
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
Old 07-03-2010, 03:03 PM   #2 (permalink)
Tinkering Addict
noahthefrog's Avatar
Gameroom cash: $101100
View noahthefrog's Photo Gallery
Have you checked your motor mounts?
Replacing my car... One part at a time
'89 Tercel EZ - 4 speed manual - Weber 32/36 Carburetor - 175K miles
3E Weber swap guide: http://www.toyotanation.com/forum/sh...d.php?t=346767
noahthefrog is offline   Reply With Quote
Old 07-03-2010, 08:59 PM   #3 (permalink)
Yes motor mounts are stirdy and nice, i removed and reinstaled engine myself, it should be secured properly, mechanic also yanked on the engine, it dose not move in its spot
I still have vibration, i cannot shift properly since i cannot hear the damn engine, all i hear is constant vibration, it does not seem to increase much, just a bit, and when RPM gets high it dissapears
Hewp
Old 07-04-2010, 06:32 PM   #4 (permalink)
I have recorded some videos, for more info.
Please check them out, they are all different, Turn up ur speakers!
Some of these make my Subwoofer on the computer vibrate realy loud, thats how it sounds inside the car
Please help
Old 07-04-2010, 07:20 PM   #5 (permalink)
Tinkering Addict
That sounds like a serious exhaust leak. I saw a big tuft of white smoke come from the area around the oil filter and exhaust manifold in the video of the engine compartment. If you've got an exhaust leak on the manifold itself or the O-ring where the exhaust pipe connects (or anywhere near the engine), it will be really loud and make the metal shielding that surrounds the manifold and exhaust pipe rattle. If the exhaust leak hits the right tone, it will make the entire car vibrate like a tuning fork.
I had a stripped O2 sensor hole in my previous car, an 87 subaru station wagon. It sounded just like that inside the car and the whole car would vibrate at a certain RPM range during acceleration, then level out to just being exhaust noise.
Old 07-04-2010, 07:30 PM   #6 (permalink)
K thanks a lot, i wont drive it anymore then, i guess ill try to find some parts
Old 07-08-2010, 06:55 PM   #7 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Your second video sounds like either header shield or exhaust shielding underneath near the cat. U still got a leak at the header though. Props for getting that motor running good. Sounds a milllion times better than before.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 07-09-2010, 07:56 AM   #8 (permalink)
Thanks man, it was the FUEL delivery after all.
I tightened the Exhaust Header onto the Engine, it sounds a bit better but the vibration is still present and constant
I will work on the car this weekend and see if i can fix it.
Old 07-09-2010, 09:22 AM   #9 (permalink)
Tinkering Addict
I'm not sure if it's present on your year of tercel, but my '89 has a pair of bolts that hold the exhaust pipe in place just above the oil pan, below the exhaust manifold. If those didn't get put back in on yours it may be rattling there also.
Old 07-19-2010, 12:56 PM   #10 (permalink)
Problem fixed! The engine mounts were loose You guys were totally right! I just could not see the bottom one
I also took of the exhaust manifold, one of the interior screws threading is gone, but the rest are ok. The gasket is competly dirty with grime, i washed it and the manifold with Stove cleaner and gas.
Then I applied almost whole of exhaust system sealant tube to both manifold, gaskets and the downpipe next to the oilpan. This stuff is quite eazy to use its sorta like toothpaste. Be sure to wear gloves! I know it wont last forever, but i hope it will solve the problem at least temporarly till i can get a new exhaust pipe. Its preaty sturdy but quite rusty.
Thanks a lot guys!
