Help: Tachometer Installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2010, 08:20 PM   #1 (permalink)
View BurnedOut's Photo Gallery
Question Help: Tachometer Installation
I have a 1989 toyota tercel 1.5L carbureted engine. Since the car doesn't have an rpm gauge, I want to install a tachometer.
I went to autozone and bought the cheapest one they got called Sunpro Super Tach II. I need a little help in installing it. It says that the green wire goes to the negative side of the ignition coil. I have a distributor ignition system, but where is the ignition coil? Is it inside the distributor?
SOLVED
I connected the green wire to the IG pin next to the diagnostic link connector in the engine compartment.
BurnedOut is offline   Reply With Quote
Old 07-06-2010, 09:44 PM   #2 (permalink)
... It still runs...
View bkftl's Photo Gallery
yeah, i need one too,
i read up on em, for the tercel 90-94 its the green black wire form the ignition coil, and the other contacts into any power outlet, i suggest sometihng that turns on and off with the engine, or else ur battery will drain. My coil has 4 wires.
Coolies u got it workin
1993 Toyota Tercel 3EE - 45,000 Miles - Odometer 280,000
*Leaking gas, Leaking Coolant, Non functoning AC, Sagging DS door. NEW TIRES!
bkftl is offline   Reply With Quote
