90 tercel wont restart when reaching operating temp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2010, 05:41 PM   #1 (permalink)
View jeddhunter's Photo Gallery
j90 tercel 2 door coupe for son. mechanic says needs new carb. they said it wont restart till it cools down. i drove it home and did notice a little surging when it was reaching normal temp while driving at about 50mph.i started it the other day and let it warm up about 50% of operating temp and shut it off then restarted it. it started ok. using the temp gauge as reference. i warmed it to operating temp and it started again but it started hard but did start. just wondering if anyone else has had this problem or heard of it. i also have been reading about the carb problems with the 87-90 models. 1.5 liter 3e. any help would be appreciated thanks jedd
jeddhunter is offline   Reply With Quote
Old 07-18-2010, 06:28 PM   #2 (permalink)
View jomersexual's Photo Gallery
I would check the ignition parts over real good because I have had intermitent problems in the past due to heat causing coils and such to break down.
jomersexual is offline   Reply With Quote
Old 07-19-2010, 08:19 AM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
See what color the spark is cold vs warmed up. That may be a very good comment jomer.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 07-19-2010, 06:20 PM   #4 (permalink)
Tinkering Addict
noahthefrog's Avatar
Gameroom cash: $101100
View noahthefrog's Photo Gallery
If you decide to replace the carb, I recommend replacing it with a Weber carb rather than installing another stock carb or doing a rebuild. I tried for years to get my stock carb to work acceptably and it just got worse and worse until the car was undriveable. Guide here: 87-90 Tercel Weber 32/36 DGEV Swap Guide
There are several vacuum switches that are a part of the original carb system which are prone to failure, plus the carb itself has an issue with allowing un-metered fuel in due to a teflon coating that dissolves in gasoline over time. This could be the cause of your surging problem if extra fuel is going into the mix and the computer is compensating by adding more air via the bleed valve, effectively the same as pressing down on the gas a little.
There are several pollution control and air bleed widgets that don't activate until the car warms up. The EGR valve and EGR vacuum modulator would be the most severe - if they were opening at idle, the car would barely work once warmed up. Also the throttle positioner system can cause surging if it decides to hit the gas at inappropriate times... on my '89 it had decided to give full throttle all the time until I disabled it. In my case, one thing after another failed on the old carb system until the car decided to idle @400RPM (which it can't) and became undriveable. It worked ok when not warmed up, despite all of the severe problems once it did warm up.
I've personally never had any ignition related problems on my car, which still worked (poorly) with all original plugs, wires, coil, alternator when I bought it @130,000miles. They could be a part of your problem, buy my bet is on the carb as the main culprit.
Replacing my car... One part at a time
'89 Tercel EZ - 4 speed manual - Weber 32/36 Carburetor - 175K miles
3E Weber swap guide: http://www.toyotanation.com/forum/sh...d.php?t=346767
noahthefrog is offline   Reply With Quote
