Hi-Amp Alternator - Stock Fit for 3E Tercel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2010, 08:59 AM   #1 (permalink)
Tinkering Addict
noahthefrog's Avatar
Gameroom cash: $101100
View noahthefrog's Photo Gallery
My alternator is going to need replacing before long and I want to get the highest output alternator I can that will fit without modding the mounting bracket or electrical connector. Looking for output around 80-90AMPs just under the limitations of existing fuses/wiring. Anyone know of an alternator that fits the bill?
Related question: Anyone know of a good way to add a fast-idle on-demand capability? I use my car as a generator with a 1kW inverter sometimes and need to make the car idle around 1200-1500RPMs for that to work. The OEM carb had a fast-idle step for ~1500RPM, but my new Weber carb only has one fast idle speed @ 2800RPM.
Replacing my car... One part at a time
'89 Tercel EZ - 4 speed manual - Weber 32/36 Carburetor - 175K miles
3E Weber swap guide: http://www.toyotanation.com/forum/sh...d.php?t=346767
noahthefrog is offline   Reply With Quote
Old 08-17-2010, 07:52 AM   #2 (permalink)
ambyrell1's Avatar
View ambyrell1's Photo Gallery
I got a 220 amp alt for my 93 Tercel, from Mechman.com, they also offer a 150 amp alt, direct bolt on, you do have to go with a different size belt, if your interested let me know and I will give you the belt size.
ambyrell1 is offline   Reply With Quote
Old 08-17-2010, 10:40 AM   #3 (permalink)
Tinkering Addict
Thanks for the info and being the only one to respond to my thread! I checked out their site, but Tercel isn't listed under toyota
I think 150amps is more than I need anyways, though, and I'm trying to avoid swapping pulleys, belts, charge wire etc. I once found an 80amp one somewhere online that was a bolt-on w/ stock connector, but I have been unable to find it again. I may have to settle for a 70amp... Anyone seen that elusive 80amp tercel alternator for sale anywhere?
