Control arm troubles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2010, 05:56 PM   #1 (permalink)
View Unterseeboot's Photo Gallery
SO. Need to replace the control arm and ball joint on my 92 paseo. I am having trouble unbolting the inboard side of the control arm. The bolts spin and there doesn`t seem to be a way for me to get inside the frame piece they bolt into. Is there a trick to this, something I`m missing?
Any help,d be appreciated. Thank you.
Unterseeboot is offline   Reply With Quote
Old 07-24-2010, 08:46 PM   #2 (permalink)
BLARRGH!!!!
Madcat's Avatar
View Madcat's Photo Gallery
The nut is welded to the frame if its just spinning it probably broke loose.
This may help:
http://insaneintention.com/forum/vie...d.php?tid=1232
Jim
I have opposable thumbs I WILL prevail.
'92 Paseo - 4E-FTE, Poly engine mounts/full front bushings, Whiteline rear swaybar, 3in exhaust.
Coming soon - Built 5E, ACIS int mani, Starion FMIC.
Madcat is offline   Reply With Quote
The Following User Says Thank You to Madcat For This Useful Post:
Unterseeboot (07-25-2010)
Old 07-25-2010, 09:49 AM   #3 (permalink)
ty
Thanks that's 50% of the problem I am having, unfortunately all three of the inboard bolts are doing the same thing for me so this is going to be a headache.
