87 Tercel Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2010, 08:58 PM   #1 (permalink)
View Dan583550's Photo Gallery
87 Tercel Engine
i got a 87 tercel i want to swap engine or build power from the 3e anyway possible i was looking into a 4a swap i need details of the fabrication and if the 4a has the same bolt pattern for bellhousing i need info
Dan583550 is offline   Reply With Quote
Old 08-02-2010, 11:52 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Look at the 4age swap in the DIY sticky and you'll see the frame cut that has to be made and the engine mount relocation. Use the whole engine and trans from a Corolla GTS. You'll need to drill/tap the trans for a mount into Tercel. All details in that thread.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
