Hey all! Just thought I would put up a thread for any suggestions on improving the MPG on my Tercel. Reason why is that I bought it with a rod through the block so I rebuilt the WHOLE thing!
I won't go into details, but the everything was machined, replaced, retorqued and rebuilt on it. PLUS I just put in the Weber conversion kit. So all sensors, pumps, belts, rings, seals, gaskets, etc were changed. The exhaust system is new from front to back. The A/T was flushed, torque converter drained and refilled, new rear-main seal, gasket and filter PLUS I used AMSOIL synthetic tranny fluid. So... the whole thing is brand new!
Additionally, the person I got it from had just put new tires, struts and paint job into it so it looks new, drives new and has TONS of pep!!! I could not be happier with this $300 car! With the cost of the car, parts, machine-work and all adds, I figure I am into it for about $1200.
I have only just put the first tank of gas through it. I adjusted the mixture halfway through it and got just over 25mpg for the first tank. I did use 89octane, but the second tank I just filled-up with I just used 87.
I think I have a unique opportunity to be able to test or tryout things that others have passed on due to the age of their engines or cars. This one is not perfect but is just as good as new.
SO HERE ARE THE QUESTIONS:
> "What things am I overlooking to be able to improve the gas milage on this car?"
> "How can I adjust the mixture to the PERFECT place to get the maximum mpg?"
> "Any other mods that you guys have considered for your cars?"
A few things I am about to redo once I get the engine broke-in completely are:
- ReAdjust the valves.
- ReAdjust the timing.
- Change the oil. (Breaking in with reg oil, will switch to semi-synth next, then ultimately to full-syth (AMSOIL)).
ANY other ideas???
Only problem I am currently having is the electric fan is not turning on and I have troubleshot it down to the wiring harness. The relays function correctly with/without voltage, the sensor was replaced again, the fan was tested to battery voltage and functions so according to the schematics it could only BE the wiring. I run the fan on high-heat to keep it midrange when it trys to heat-up, but overall it runs cool. I also made a cooling air bleed port so I am sure that is not the problem too (or contributing to it anyway). If you have any suggestions I am open to them and appreciate them.
Alright. I look forward to your inputs and love this little car and look forward to something around 35mpg. So watcha got??
