suspension work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2010, 10:18 PM   #1 (permalink)
View blackhawk tercel's Photo Gallery
Gen5 suspension work
ok i changed the wheel bearings , the ball joints, struts, and the driver side axle, and now my tercel makes a noise like if the wheel bearin is bad but its new tho so i want some advice on that please, and also my tercel steering wheel shakes at low speed and high speed too wat can it be? but the tie rod are ok and also where can i find springs that will drop my car 2in? i found some but they only drop it 1.9 in and their tein springs
blackhawk tercel is offline   Reply With Quote
Old 09-01-2010, 12:07 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
What kind of noise? High pitch, low pitch? Grinding or rubbing? Check and make sure you didn't bend the rotor shield while doing the work. Re-check all bolts to be sure they're tight. Are you tires old? 'Out of balance' wheels may be causing the vibrations. As for the springs, Tein is said to be a reliable and well made brand. I doubt you'll notice the 1/10th inch difference so go with the Teins.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 09-01-2010, 02:28 PM   #3 (permalink)
low pitch cause i gotta turn down the cd player to hear it and is like a grindin noise kinda but its only the driver side tho , idk iam goin to buy the inner and outer tie rod to see if its that and also change rims in the front. but thanks alot man
