Burnt valve - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2010, 08:53 AM   #1 (permalink)
View m_wnzl's Photo Gallery
Burnt valve
What exactly does a burnt valve look like, and can it be reused if you lap it?
m_wnzl is offline   Reply With Quote
Old 09-05-2010, 12:41 PM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161115
View 96paseo's Photo Gallery
Typically whitish-yellow appearance and coarse feel on the lip where it meets the seat. The valve themselves aren't all that expensive but the getting the head checked and re-worked is what is. Re-using the old one is not a good idea.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 09-07-2010, 07:36 PM   #3 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Its very common to have a peice missing from a burnt exhast valve.
Sometimes a pie shaped section will be missing from the head of the valve and you will have zero compression on that cylinder.
When you remove the valves they are always dirty and encrusted with carbon ( even when the valves are good).
What separates a burnt valve from just wear ,is on a burnt valve the damage is done by hot gases( exhast gases) eroding the valve.
Not having your valves adjusted properly is one common cause.
When they are too tight they dont rest long enough on the valve seat( that helps cool the valve through conduction) and they overheat and fail.
sam333 is offline   Reply With Quote
