Engine Swap Question - 3F motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2011, 10:47 PM   #1 (permalink)
View cattlick's Photo Gallery
What other motors can I bolt into this 94 tercel? its got a 4spd would like a 5 but take what I can get. Looking mainly to improve the motor.
Thanks
C
cattlick is offline   Reply With Quote
Old 12-21-2011, 06:39 AM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Read the engine swap sticky thread as it covers all the options and what's required for each.
Common Engine Swap Guide
For a quick low budget swap look at a first gen 5efe from a Paseo and it's 5speed. Drops right in and uses your wiring.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 12-21-2011, 03:26 PM   #3 (permalink)
View The_KID's Photo Gallery
Sounds like what I need to do for my Tercel...
No mods required...?
And what year Paseo would this be...?
Thanks
The_KID is offline   Reply With Quote
Old 12-21-2011, 07:00 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
92-94 in most areas.
雄のハヤブサ
Old 12-22-2011, 07:47 PM   #5 (permalink)
I found a Corolla in a yunk yard but not sure what year corolla
(maybe 92-94...etc )
Thanks
1) Can anyone tell me what E-type motor this is?
2) Will this motor work directly in my 94 Tercel as a swap?
Old 12-23-2011, 05:49 AM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
Corolla have A block. Read the stickies for what that requires. Check http://car-part.com if you don't have many salvage yards nearby.
雄のハヤブサ
Old 12-24-2011, 02:29 AM   #7 (permalink)
View brandonprice's Photo Gallery
Sounds like you need an Italian tune up! Give it a good hard run then change the oil. This problem can occur if you do a lot of low miles especially in winter. I don’t think you have anything to worry about.
used car sales
brandonprice is offline   Reply With Quote
