Hi
I am having a very tough time determining the problem with my 87 tercel 5 speed manual coupe.
My clutch will not work for shifting any gears. Leading up to this problem I would have to shift it with half the pedal engaged just to get it in gear. A few times I would really have to play with the pedal before I could even get it to start shifting at all. I am not exactly sure where the problem is. One day it was locked up after starting it outside. Pressing the pedal had a lot more resistance when it would lock up. Id usually press the pedal a bit and it would start to work again, but this time the pedal felt like it went all at once. There is very little pressure now. The brake fluid hasn’t dropped by much only about a centimeter and half within 4 weeks. The breaks still work good. Now there is no way it will shift into gear while its running, The transmission is very tight and has no problem getting into any of the gears while its off. I am not sure if there is a problem with the hydraulics or if the fork or bearing is messed. Any advice would be quite helpful.
Thanks
