Shop Manuals/Exploded Parts Views - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2012, 08:02 PM   #1 (permalink)
View Ntrdr101's Photo Gallery
Hello,
I'm doing a coolant system replacement on a 82 Tercel, and was wondering if the there are any other shop manuals besides the Haynes manual for this vehicle?
Is there anywhere on the net someone could link me to where I can view expanded parts/components views?
Not having issues persay, would just like more detailed images than the limited explanations contained in Hayes Manual.
Cheers,
Ntrdr101 is offline   Reply With Quote
Old 01-03-2012, 05:54 AM   #2 (permalink)
View expertmax's Photo Gallery
I have access to Alldata and Mitchel onDemand, which are two big selling car repair software and I could not find specific procedures for a coolant flush.
You will need : 2.6 liters of water and 2.6 liters of coolant (ethylene-glycol).
The best way to flush your coolant is to remove the water outlet hose (the bottommost hose from the thermostat housing) from the thermostat (remove the radiator cap to help gain back pressure), wait for the coolant to drain and then reconnect the hose.
Put 1:1 water/coolant solution in the radiator until it overflows, start the engine leave the radiator cap off, turn your heater to MAX and temperature on HOT, and continue adding coolant. When the coolant overflows again, put the radiator cap on and wait for the radiator fan to start and then stop the car.
Let the car sit for 10 minutes, remove the radiator cap carefully and add coolant until the radiator overflows. put the radiator cap back on and fill the overflow reservoir to the right level.
Now test drive your car and check if the engine temperature is at the right spot.
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
expertmax is offline   Reply With Quote
Old 01-04-2012, 05:36 PM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161315
View 96paseo's Photo Gallery
Factory service manual on ebay.
http://www.ebay.com/itm/1982-TOYOTA-TERCEL-AL-12L-ORIGINAL-DEALER-SERVICE-DEPARTMENT-REPAIR-MANUAL-/160700492099?pt=Vintage_Car_Truck_Parts_Accessorie s&fits=Year%3A1982%7CModel%3ATercel&vxp=mtr&hash=i tem256a7ee943
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 01-04-2012, 05:48 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3642750
Excellent find, and at a great price!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
