starting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2012, 09:06 PM   #1 (permalink)
View kulfi's Photo Gallery
starting problem
i have toyota tercel 95 and when i on the ignition it takes some time to start please can u advice what is the problem.
thanks
kulfi is offline   Reply With Quote
Old 01-06-2012, 05:20 PM   #2 (permalink)
Tinkering Addict
noahthefrog's Avatar
Gameroom cash: $101100
View noahthefrog's Photo Gallery
With only the info you provided, all I can suggest is to hold the gas pedal down halfway while cranking the car until it starts. Without more info, any answer to your question is really just a guess. Does it cough like it's trying to start or does it turn over for awhile and then fire up like nothing is wrong? Does the car have other problems or strange behavior like poor gas mileage, stalling, etc?
Replacing my car... One part at a time
'89 Tercel EZ - 4 speed manual - Weber 32/36 Carburetor - 175K miles
3E Weber swap guide: http://www.toyotanation.com/forum/sh...d.php?t=346767
noahthefrog is offline   Reply With Quote
Old 01-06-2012, 06:22 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
I would like to see pictures of a Saudi Tercel.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-07-2012, 10:40 PM   #4 (permalink)
Yes, i will tell u in more details i am not a technician but the owner
when i insert the key and rotate to start no respons than i repeat again than it is trying to satrt with low sound like "chuk" "chuk" and suddenly the sound increases and it starts.
I hope u understand the problem now can u please let me know what the problem is.
thanks
Old 01-08-2012, 01:35 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
That sounds like a bad starter. The solenoid wears out and causes a light click sound with no spin. Does this match your problem?
雄のハヤブサ
Old 01-08-2012, 07:01 AM   #6 (permalink)
When the car is running for long period than it is so or either it is cooled than so but i observe one thing when the car is standing under the sun or the body is heated us it starts quickly can u show me in the egine diagram which component is bad.
thanks
Old 01-08-2012, 09:04 AM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
Here's a quick link I saw on google that shows/sells both type.
http://www.starterpros.com/gstarters...FQpR7AodTjHahA
You won't know which you have until you see it. The starter is behind the engine bolted to the transmission. To remove it requires taking off the air filter box and tubing plus disconnect battery. The bolts holding it on have 14mm heads and a 12mm nut holds one wire on while a clip holds a second wire. The wires are accessed from under car easiest.
雄のハヤブサ
