I've used Fel-Pro HG's twice now and have been impressed with their quality. Hard to tell the difference between them and OEM. Neither HG has had any problems after replacement either. Don't forget to get a new set of head bolts for the job.
The rock has Fel-Pro upper gasket sets for a good deal. If you do go with Stant for the t-stat, get the OE design. They cost a bit more but are worth it.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.
New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
