head bolt torque - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2012, 01:33 AM   #1 (permalink)
N/A bites
Tercel GTS's Avatar
head bolt torque
So today I reinstalled the head on my 5efe and got to use my snap-on torqometer for the first time in a real world test. I was right too! Using torque to yeild bolts even with proper lube on the washers and bolts resulted in extremely different torque values.The shorter bolts were torquing at 575-585 inch/lbs while the longer bolts only made 425-430. I set them all to the 585 in/lbs so they'd all be the same instead of attempting to back one off. If I have any issues I'll share. I wish I had gotten pics of the domed pistons. It really suprised me to see the 5efhe pistons I so much wanted. This engine came from a local salvage yard and appeared to be a rebuild even though all the seals are hard and brittle. I can't seem to find a correct oil pan/dip stick/tube combination either. One combo reads near correct but hits the bottom of the pan. Another combo says with 3.5qts it has no oil touching the stick.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
