new guy here! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2012, 09:49 PM   #1 (permalink)
View pase...OH!'s Photo Gallery
new guy here!
hi all, im new here but not to forums at all. I have a 93 paseo that i got for $700 and i have to say i think im hooked, for the millage and use it had before i bought it, it is in decent condition. that being said i am very familiar with working on cars and i am not sure about a couple things, it idles at 900 rpm i think thats a little high, or am i wrong? it runs rough enough to shake the steering wheel at idle and has a vibration through out the rpm range. it did over heat and blow the head gasket before and the previous owner put a new one in. i have done a tune up ( cap, rotor, wires, plugs, pcv, air filter, oil change) and its no diffrent but i do get around 33 to 35 mpg! much better than my chevy 2500 that gets 10mpg hahaha is there anything notoriously wrong with the 5e that i missed? thank you all i hope to hear from some one
pase...OH! is offline   Reply With Quote
Old 01-24-2012, 09:02 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
900 is dead accurate. Most 4 bangers have a slight vibration but if it's worse than that check for skips. My 92 has a strange habit of getting water inside one spark plug tube. Once the water is so deep the plug misfires. It starts at higher temperatures under load and becomes a full time skip until dried. I'm suspect of the scoop on the hood that I did not install and yes it has an open hole to the engine.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-26-2012, 01:50 AM   #3 (permalink)
View expertmax's Photo Gallery
Your car should idle at around 750 RPM. To adjust it, see image.
You can check your ignition coil, primary resistance and secondary resistance (see image)
You might want to check your timing belt, if it has skipped teeth.
Use a timing light and check for proper timing. (10 degrees BTDC)
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
expertmax is offline   Reply With Quote
Old 01-27-2012, 10:52 AM   #4 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161315
View 96paseo's Photo Gallery
Broken motor mounts can transmit lots of vibration even when the engine tuned properly. Rev the motor up and down by hand and look for excessive engine movement.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
Old 01-27-2012, 09:27 PM   #5 (permalink)
View dana0330's Photo Gallery
Mine had a skip after doing a tune up found that #2 cylinder was causing the skip. Found the injector was bad replaced the injector and the skip is gone now.
dana0330 is offline   Reply With Quote
Old 01-28-2012, 08:53 AM   #6 (permalink)
thank you every one im going to look into all of this in the next couple of weeks, o r as soon as work permits. i know the "idle" screw under the butterfly linkage is adjusted to hold it open right now if I back it all the way off it dies, is this normal for these?
