Engine replacement question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2012, 12:26 PM   #1 (permalink)
View wags70ss's Photo Gallery
I have a 92 Paseo with the 1.5L engine & a manual trans. It belongs to a customer. The engine is bad & he wants a new engine put in. I have been told that I have to get a manual trans engine, or if I use an automatic trans engine, I have to swap over the intake & exhaust manifolds & the "water castings", whatever those are.
Can anyone tell me if all this is nessessary with an automatic trans engine?
wags70ss is offline   Reply With Quote
Old 01-24-2012, 04:52 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
No it isn't, they're all the same. You may want to keep the temp sensor though as I've found they give unique readings.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-27-2012, 10:47 AM   #3 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $161315
View 96paseo's Photo Gallery
Automatic uses torque converter and manual uses flywheel. You'd just have to swap parts to keep the MT setup if you got a motor split from an auto tranny.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 264,xxx miles - New output shaft seals, Trans fluid service...
1997 Mazda B2300 213,xxx miles Underbody/frame resto in progress.
Find my DIY's or advice helpful? Don't forget to hit the "Thanks" button.
96paseo is offline   Reply With Quote
