My summer project : Swapping a 4E-FTE.
Hi there !
I know the subject has been covered multiple times on this forum but when I need to invest money in things I'm not 100% sure they will work, I'm worried.
I have a 1999 Toyota Tercel 5E-FE 5-Speed and I want to swap the engine for the 4E-FTE. I was wondering if there is things I should consider before the swap.
As for mounts, everything fits bolt-on. The tranny fits bolt-on too. But what about the engine harness. Is there any way I can just cut and solder some wires from my original harness to fit the new ECU or the layout is not the same and I really need the new harness ?
I'm thinking about putting a bigger turbo because the 4E-FTE turbo is the worlds smallest turbo. Do you have suggestions ?
Thank you and I will keep you up with the updates and post pics !
2001 Toyota Corolla 5-M/T (1ZZ-FE)
1999 Toyota Tercel 5-M/T (5E-FE)
"What's the blood type of a Honda Civic driver ? Type-R" -expertmax
