Oil pump question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2012, 02:11 PM   #1 (permalink)
View The_KID's Photo Gallery
Oil pump question
I'm in the process of completing a swap from 4E-E to 5E-FE in my 94 Tercel with 65K miles.
I decided to use the oil pump from the Tercel because it has a lower mileage than the donor 92 Paseo with 120K miles.
After installing I noticed there is a slight free play when I pull on the oil pump pulley. I just wanted to ask if this is normal or is it defective(worn). Or are they not interchangable?
I re-checke that the bolts are tight and is fully flush with the block.
The_KID is offline   Reply With Quote
Old 01-30-2012, 08:13 AM   #2 (permalink)
Here's what I found out for those interested...
This 5E-FE block has a recessed slot at the oil pump cog, whereas the 4E-E does not.
I had to put back the original 5E-FE oil pump and all is good to go.
Thanks
