How do I change my spark plugs on my 97 Toyota Tercel? - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 3 Old 01-22-2013, 01:39 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I need to change my plugs. Where are they located? Please tell me what I need to do and what size plugs I need. I have a 97 Toyota Tercel CE. Thanks for the replies.
97_ToyotaTercel is offline
post #2 of 3 Old 01-22-2013, 08:55 AM
Account canceled
Quoted: 28 Post(s)
Pretty easy to do. Tools you'll need: 3/8" ratchet, 12" extension, 5/8" spark plug socket, 10mm wrench or socket, anti-seize for the new plugs. To get started, unplug the wire harness from the ignition coils. Just squeeze the tab and pull. Remove the spark plug wires from cylinder 1 and 2. One 10mm bolt holds each of the igniton coils in place. Remove and pull/wiggle the coil till it comes out. Move the coils/wires aside. Remove old spark plugs. Coat the threads of new plugs with anti-seize. Install new plugs and tighten 12-18 ft lbs. Reassemble and go!~ Plug numbers below. Stick to DGE(dual ground electrode) plugs for best performance. See pic below.
Denso #PK16TR11 Double Platinum
NGK #BKR5EKB11 Standard Copper NGK #BKR5EKPB11 Laser Platinum
96paseo is offline
post #3 of 3 Old 01-22-2013, 09:12 AM
Account canceled
Quoted: 28 Post(s)
96paseo is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Tercel, Paseo, Starlet, and Sera Forum
User Tag List
Linear Mode Linear Mode
ę Back
