95 Tercel - Check engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2004, 11:00 AM   #1 (permalink)
View cjhudson101's Photo Gallery
Yesterday, while driving home for lunch my Check Engine Light came on. The car itself has been driving as it usually does, no noticable changes. No weird smells, or emissions that are visible. I had the oil changed about 2 weeks ago, checked the oil etc... looks fine to me. The only things I can think of is the coolant is a little low which I am going to fill today, and also my car does a shudder when I engage the clutch in first gear. I sometimes feel it slip a little when I shift to second, however this is normally only when the engine is cold. Once it is warmed up it doesn't happen in second and occasionally happens in first. However, since the engine light came on it seems like it is happing a little more frequently. I am taking my car into the shop tomorrow however I was hoping there was something you guys might suggest to check before I take it in. I am wondering if I might be low on other fluids like transmission fluid etc???
Any help would be appreciatted!
Thanks,
--Chris
cjhudson101 is offline   Reply With Quote
Old 10-20-2004, 04:33 PM   #2 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
Low fluids generally won't cause a check engine light. Since that car is OBDII you'll need a scanner to find out what the trouble code is.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 10-21-2004, 12:46 AM   #3 (permalink)
View kene's Photo Gallery
Autozone rents them out, then when your done they give you your 199$ back. i think the time limit is 1 week.
kene is offline   Reply With Quote
Old 01-09-2008, 04:21 PM   #4 (permalink)
View rachelvegas's Photo Gallery
unfortuinatly auto zone only has OBDI. for the 95 it requires OBDII and they do not carry them...sorry
rachelvegas is offline   Reply With Quote
Old 01-10-2008, 03:54 PM   #5 (permalink)
View Daox's Photo Gallery
If you simply go to autozone they will scan the car for you for free. I did this many times before I had a scanner. Advance for sure, and others probably do it as well.
Daox is offline   Reply With Quote
Old 01-13-2008, 09:17 AM   #6 (permalink)
View ksmtnbkr's Photo Gallery
Make sure the gas cap is tight. You may need a new gas cap. If the cap is not tight it will cause vaccum problems with the fuel system. Has happened to me with several cars. Once you tighten the cap you can reset the check engine light by pulling the fuse, wait a few seconds, and replacing it. If the light comes back on its something else.
ksmtnbkr is offline   Reply With Quote
Old 01-15-2008, 03:29 PM   #7 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
:o)
Talk about raising the dead. This thread was stopped from Oct 2004.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
