Speedometer Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2005, 03:26 PM   #1 (permalink)
View Bettendorf's Photo Gallery
I Have a 1991 Tercel, 3E-E, 5-speed manual. Just recently, the speedometer will not read until I get to about 20-25 MPH then is starts to work. The odometer is working even when the speedometer isnt. Anyone have any suggestions?
Thanks,
Jeff
Bettendorf is offline   Reply With Quote
Old 03-04-2005, 05:08 PM   #2 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
the cable is probably slipping and when it hits the speed it probably catches or something
Hatch is offline   Reply With Quote
Old 03-04-2005, 06:44 PM   #3 (permalink)
That is what I thought at first, but don't the speedometer and odometer work off the same cable? My odometer always works, even when the speedometer is not.
Jeff
Old 03-04-2005, 08:06 PM   #4 (permalink)
View dexter_5000's Photo Gallery
check under the hood to make sure its in there tight sometimes they come loose.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 03-05-2005, 10:25 AM   #5 (permalink)
View Qballcious's Photo Gallery
it's not the cable
since the odometer always works but the speedo doesn't means it's not the cable. It could be something as simple as a loose needle or a as serious as a buggered speedo. Hit the salvage yard and pick up a "new" one for like $10
Qballcious is offline   Reply With Quote
Old 01-03-2008, 07:44 PM   #6 (permalink)
mag
View mag's Photo Gallery
Did you fix this problem? was it the gauge or the cable? I have the same problem, please let me know...
mag is offline   Reply With Quote
Old 01-04-2008, 09:20 AM   #7 (permalink)
View Daox's Photo Gallery
If the speedo is messed up and the odometer is fine, follow Qballcious' advice.
Daox is offline   Reply With Quote
Old 01-04-2008, 12:26 PM   #8 (permalink)
mag
Thank you, yes the odometer works fine but the speedometer is flipping out, the needle moves but only around 10-40 flipping. I will get a new speedometer and a speedo sensor (I have heard they brake down) and will check the wire. Do you know where the wire is connected in the engine room? Thank you
Old 01-04-2008, 07:38 PM   #9 (permalink)
View Helps's Photo Gallery
pull your dash apart and rip that thing out. on the back you can unsnap the speedo cable. lube up inside real well and put it all back together. problem fixed.
Helps is offline   Reply With Quote
Old 01-04-2008, 09:47 PM   #10 (permalink)
mag
Thank you, I will try that. Do you lube it with WD40 or with heavier stuff?
Old 01-05-2008, 02:22 AM   #11 (permalink)
wd 40 would work but it would cause it to get dirty fast. i used some silicone lubricant in a can.
