water pump location? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2005, 09:41 AM   #1 (permalink)
View fidnee's Photo Gallery
Question water pump location?
I have a 1994 tercel. if the water pump is not working correctly what are some signs/symptoms? Also where is the location of the water pump? thanks
fidnee is offline   Reply With Quote
Old 04-23-2005, 05:06 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Leaking water, running hot. Water pump is on belt side of engine under timing belt covers, powered by timing belt.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 04-23-2005, 10:34 PM   #3 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
on my 93 which should be the water pump is just behind the timing cover, not under it. powered by the same belt as the alternator. could be wrong though
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 04-24-2005, 05:06 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Maybe you're right, I haven't put one on the e-series engine, just my s-series.
雄のハヤブサ
