3E-E stripped head bolts. Any suggestions? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2005, 03:37 PM   #1 (permalink)
View izekat's Photo Gallery
Exclamation 3E-E stripped head bolts. Any suggestions?
damn it, stripped a couple of head bolts while trying to change a gasket. Any ideas with how to extract these bolts? I dont want to get in there with a drill and core the bolts out, lest it slips and makes a new hole in the head. i was thinking of getting some vise grips in there, but there just isnt enough space! Any suggestions will help.
izekat is offline   Reply With Quote
Old 04-27-2005, 06:15 PM   #2 (permalink)
Toy-Cel
TdotTercel's Avatar
View TdotTercel's Photo Gallery
Cndn Tire has those things that you can kinda screw into the head of the bolt and remove it... don't remember what they're called
1992 Tercel DX
JDM 5EFHE, SRI, ACIS, 4-2-1 headers, 2" exhaust, Magnaflow Hi-Flow CAT
TdotTercel is offline   Reply With Quote
Old 04-27-2005, 08:34 PM   #3 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
craftsman has diferent types of bolt extractors. im sure theyll have one that will work and they arent very expensive. if you have a craftsman dealer in your area. heres what im talking about... http://www.sears.com/sr/javasr/produ...id=00952166000
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 04-28-2005, 08:00 PM   #4 (permalink)
Thanks for the tips fellas, but the tercel uses XZN / triple square bolts that are round on the outside, so the common bolt extractors wont work. I knew i should have ordered the Toyota SST!
Old 04-29-2005, 07:43 AM   #5 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
how about welding a nut on the top of the broken bolt? the opening in the center will be enough to get the nozzle in there!
BTW: i've never ever used an SST to remove head bolts. i've rebuilt the 3E many, many times!
ToyotaTechGeek is offline   Reply With Quote
Old 04-29-2005, 06:53 PM   #6 (permalink)
View thoughthard's Photo Gallery
Dremel a slot in them and use a screwdriver to remove...?
thoughthard is offline   Reply With Quote
Old 04-29-2005, 07:04 PM   #7 (permalink)
N/A bites
Tercel GTS's Avatar
Get some left hand threaded bolts and force thread them into the triple square holes. As you tighten them the bolts will release. If this won't work then hammer some bolts into the holes, tack weld them and then remove. Did you have the proper tool to start?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 05-01-2005, 08:02 PM   #8 (permalink)
nope .. i used a ghetto 5/16 hex key instead of the toyo SST. It opened 8 of the 10 bolts without any problems. I *did* buy the XZN bit, but the wrong size ... (apparently toyota makes one which is 8.99mm in size) and i bought 8mm and 10mm. I did find something interesting though .. its called a 'multi spline bolt extractor' looks just like an easy out but designed for socket bolts. Will call my local snap-on truck to get the down and dirty on this tool. Once i know how it works .. you lot will know how it works!
