1994 Tercel smoking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2005, 07:27 PM   #1 (permalink)
View teamdominion12's Photo Gallery
1994 Tercel smoking
I have a 1994 that i just recently got that wasnt running on all cylinders. I got it running but now its smoking pretty bad. I tried putting sea foam down through the cylinders to loosen up the oilrings on the pistons. and it helped but its still smoking so im in the process of doing that again. Does anyone have any other suggestions of what else could be causing it to smoke like this. It isnt too bad idling, but is much worse when accelerating.
If you have any suggestions let me know.
teamdominion12 is offline   Reply With Quote
Old 05-24-2005, 10:24 PM   #2 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
what color smoke? according to my shop teacher...white is coolant, blueish is oil, and black is gas. as for getting worse while accelerating.. timing maybe? hope this helps
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 05-24-2005, 10:58 PM   #3 (permalink)
Corsa!
Galvatron's Avatar
View Galvatron's Photo Gallery
I'd say valve stem seals, or if its obnoxiously bad, piston rings, assuming it's blue smoke.
1992 Tercel DX, 3E-E/3AT
1992 Paseo, 5E-FE/5MT
2007 Suzuki SV650S
http://www.rent-a-tech.org/wordpress
Galvatron is offline   Reply With Quote
Old 05-26-2005, 11:22 AM   #4 (permalink)
Its blue smoke, sorry for not specifying. We are thinking that its the oil rings on the pistons. If its blue smoke would that have anything to do with timing or no?
Old 05-26-2005, 11:23 AM   #5 (permalink)
Would valve stem seals being bad cause blue smoke. Its pretty bad.
Old 05-29-2005, 08:23 PM   #6 (permalink)
View piggyfinndude's Photo Gallery
valve stem seals USUALLY only smoke at start up and acceleration from idle....
do a compression test and see if it's the piston rings. Remember...piston rings are metal, so don't think that these products are gonna "moisten" them like some do to rubber o-rings or whatever for power steering etc. I personally think that anti-smoke stuff is bull, just makes the oil thicker is what it does!
good luck!
piggyfinndude is offline   Reply With Quote
Old 06-02-2005, 06:48 PM   #7 (permalink)
Piston rings werent the problem. we replaced them and its still smoking badly. Any more suggestions.
Old 07-11-2005, 03:44 PM   #8 (permalink)
View Mike Kamm's Photo Gallery
Did you have the head pressure checked for cracks when you rebuilt the lower end? Were the guides loose?
Mike Kamm is offline   Reply With Quote
