as to 1 and 2 dunno but for 3, you should be able to pull the codes using your key, turn it ON,OFF,ON,OFF,ON pretty quickly, after a sec or 2 the check engine light will start flashing out the codes, a number of flashes(for the first #), a small pause then more flashes. in between codes there is a longer pause. the drawback: you need a manual to ID the codes. write down the codes and try looking on the web for discriptions and see what you can fix yourself. ive done it on two cars and it worked nicely but dont quote me on any of this as im not a mechanic
edit: i looked in the manuel for my car and to pull the codes with the key i have to put a jumper wire in the diagnostic connector. i cant remember which termials though. sry!
 Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
