Brand new brake pads, brake pedal still bottoms out!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2005, 11:40 PM   #1 (permalink)
View izekat's Photo Gallery
I just replaced the brake pads on the paseo, the pedal still bottoms out but now the car is pulling to one side when i brake. Now, pumping the pedal a few times prevents it from bottoming out and gives me some brake response. Am i bleeding the brake system incorrectly?
(i bleed by pushing the caliper inwards while letting oil squirt out of the bleeding nipple, then i tighten it while the oil is still weeping out.). Help will be appreciated ... thanks guys.
izekat is offline   Reply With Quote
Old 05-28-2005, 02:21 AM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
Get a friend to push the brake pedal while you bleed the brakes into a jar with a tube. Buy a bleed kit and get some of those quick bleeders to make it super easy.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 05-28-2005, 01:02 PM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
If you pump the brakes and it gets a little better you probably have a master cylinder problem. Pumping the brakes wont change the pedal feel if you have air in the lines.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 05-29-2005, 12:21 AM   #4 (permalink)
View dexter_5000's Photo Gallery
when you change out disc brakes you should be able to just take off the master cylinder cover and push the calipers back in no bleeding should be involved. unless you are replacing a caliper and allowing air into the system. you may have to bleed the system now though.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 05-30-2005, 05:30 PM   #5 (permalink)
Thanks for the all the replies guys. Bled the brake system with the aquarium air tubes, the brakes are now .. perfect (as can be on a 13 year old car). Looks like i need to change the rear shoes as well. ciao for now.
Old 06-26-2005, 09:58 AM   #6 (permalink)
lancekilgore's Avatar
View lancekilgore's Photo Gallery
Hello, you need to adj the back breakes, I recently replaced mine all around and expected the self adjusters to work but they did not so I manually adjusted the back brakes and and I now have the full pedal back. also an easy test to check is how many clicks you have to pull the parking brake handle if it is more than 5 then defanatly adj the back brakes.
Lance
lancekilgore is offline   Reply With Quote
Old 06-26-2005, 11:35 AM   #7 (permalink)
those auto adjusters rarely ever work so yes you should always manually adjust the brake shoes with a drum spoon
dead 8/23/2005
