Fuel or Electric problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2005, 05:02 PM   #1 (permalink)
View racerui's Photo Gallery
Question Fuel or Electric problem
I've got a 95 Tercel, 210k, 5spd. Once in a while, when accelerating through the gears, the engine stops accelerating for 1/2 second and then jerks. The fuel filter is new. Could this be the fuel pump, or an electrical problem.
Has anyone experienced this problem before?
racerui is offline   Reply With Quote
Old 06-03-2005, 06:02 PM   #2 (permalink)
View thoughthard's Photo Gallery
I have a similar problem. Whenever the engine was under load, it would hesitate. At constant speeds, it was fine.
I replaced the spark plug wires, spark plugs, cap & rotor. Problem solved.
thoughthard is offline   Reply With Quote
Old 06-06-2005, 05:27 PM   #3 (permalink)
My tercel doesn't have cap or rotor, and the plugs are new bosh platinum. I once had a check engine light show up, but i just reset the system and ignored it. If it was an oxigen sensor i should be having low gas milage, but i can do around 700Km with 35liters of supreme gas. which i think is pretty good. Could any other sensor cause this? Could it be the fuel pump?
