Newbie needs help with stallingTercel
My '89 Tercel started running hot so I checked and saw the radiator fan wasn't running. I tried to see if the fan relay in the fuse-relay box was bad - I used a jumper across the slots where the relay goes. Oops, spark; click somewhere. Now, the engine starts but continues to run ONLY if I jiggle/pump the accelerator. So it won't run with a load and it will stall if I floor it or hold the accelerator still. I killed it but I don't know what to do to ressurect it. I can't read codes because this model doesn't have a check engine light. I replaced the PCV valve but no change. What's next?
