93 Tercel A/C - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2005, 06:35 PM   #1 (permalink)
View millennm's Photo Gallery
93 Tercel A/C
Well my mother's Tercel A/C isn't working. The clutch isn't engaging when the A/C button on the dash is pressed. Therefore, I guess there is a freon leak and a low pressure switch on the compressor is keeping it from engaging. So I'm going to add freon to the system to see if the clutch will start working. I heard that there was a freon change over from R12 to R134 between '93 and '94. Well, if anyone knows which refridgerant the '93 Tercel takes please respond. Also how do you know when you've entered enough refridgerant. Do you have to hook up a guage to the high or low side? What would the full pressure be?
Thanks
Keith
millennm is offline   Reply With Quote
Old 06-13-2005, 07:19 PM   #2 (permalink)
View dexter_5000's Photo Gallery
best to bring it to a dealer and shell out the cash in most cases with ac you have to be certified and have a machine to put it in.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 06-13-2005, 11:39 PM   #3 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
It would be a good idea to convert it to 134a, it'll cool better and you can add refridgerant youself in the future. Have a certified tech evacuate the system and you can go to any auto store(like advance auto parts or autozone) and get a r12/r134a conversion and save$$. It will come with a gauge so you don't have to worry about over filling and screwin somethin up
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 06-18-2005, 08:05 PM   #4 (permalink)
View Mystral Hawk's Photo Gallery
Well my A/C just entirely died...so do any of you gurus have any solution to this predicament? Its kinda pricy to install a new one...
Mystral Hawk is offline   Reply With Quote
Old 06-25-2005, 04:30 PM   #5 (permalink)
View thoughthard's Photo Gallery
millennm,
On my 92 Paseo, the wiring that went from the dash button to the compressor fried itself in two near the radiator area. Has done it twice now. You might want to troubleshoot first before adding freon.
thoughthard is offline   Reply With Quote
Old 07-02-2005, 02:38 PM   #6 (permalink)
View jeffs94's Photo Gallery
Thanks
Keith
I dunno when toyota changed from R-12 to R-134a but i do know that the oil will have to be changed out along with the O-rings seals(the oil and for the different refrigerants is not compatiable and in most cases neither is the O-rings). If it already had R-134a then have it evacuated or better still, have a certified pro do it....they will know what to do, how much to put in and will be able to find the cause of why it no longer works (the leak). A system with the wrong type of oil mixed with the wrong type of refrigerant can be an expensive fix. R-134a systems use quick disconnects and R-12 systems use threaded connectors on both the high and low side.
jeffs94 is offline   Reply With Quote
Old 06-06-2006, 08:09 PM   #7 (permalink)
View paseonate's Photo Gallery
so.. my 93 paseo is pumping lueke warm air into my car in already 100+ weather.. the ports off the low pressure and high pressure lines are not threaded so i figured it was 134A but after filling it to proper psi it still is pumping that god forsaken warm breeze.... so i kept checking the pressure in the lines every 5-10 minutes about 5 checks so far and no decrease in pressure that i can notice... so has anyone learned any troubleshooting techniques yet?
paseonate is offline   Reply With Quote
