Along with the wire harness/connector, ($6-8) You will probably need to get an adaptor to convert the Japanese wire system to a trailer wire system, since trailers usually have the same lights work as turn signal and brake lights. These wires and adaptors can be bought at just about any auto parts store, Wal-Mart, K-Mart or any place that sells trailer or auto parts stuff. They usually cost about $12 - $15, and have very simple instructions. The hardest part is usually gaining access to your tail light wires, then figuring out which is brake light and which is tail light wire.
If the trailer is already wired, make sure you get a connector to match it. The most popular style of connector is the flat kind with 4 wires (Green/yellow/brown/white).
The colour code for the '92 Paseo tail lights is:
Left turn is a green wire with a black stripe.
Right turn is a green wire with a yellow stripe.
Brake light is a green wire with a white stripe.
Tail light is just a green wire.
I think the '93 should be the same but I am not sure.
Be careful, sometimes it is difficult to tell the difference between the green/yellow, and the green/white.
Good luck.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
