Valve related question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2005, 05:08 PM   #1 (permalink)
View Hepcat's Photo Gallery
Question Valve related question
Hi, i'm new here, been told that I can have good advice here
I need help, it concerns a 93 Tercel.
I removed the head, because of good/poor/no/no compression, lo
What I found: a broken valve(1 exhaust). Afterm removing the broken valve, do I need
to have the valve seat done? Or if the valve doesn't leak, I can leave it like this(gona do a leak test with some liquid).
Thx alot
Hepcat is offline   Reply With Quote
Old 06-30-2005, 09:14 PM   #2 (permalink)
View TercelFix's Photo Gallery
Go to canadain tire and get valve grinding compound, and the tool with the suction cup. Put the new valve in place with some compound around the 45 degree seal and rotate it a few times, remove wipe with a rag and look, you will see if it sits properly. If not keep on going untill both surfaces that contact are shiny! You will have to adjust for valve lash once the head is reinstalled.It is so easy to do you should check the other valves while you are at it.
TercelFix is offline   Reply With Quote
Old 07-02-2005, 02:21 PM   #3 (permalink)
View jeffs94's Photo Gallery
Thx alot
What caused the valve to break in the first place and where did it break at? The stem? the face? was it bent or burnt? and did it damage the guide or nick the valve seat?
jeffs94 is offline   Reply With Quote
