Oldtimer needs some advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2005, 11:48 AM   #1 (permalink)
tired of swingin a wrench
View WanderR's Photo Gallery
Is this the nation that can bail me out.I hope so.
Here's the the scoop.I purchased a 92 turtle for my daughters first car.Had a blown motor,so it was next to nothing.Started reading your forums and picked up a paseo motor.Everyone said it was an easy swap.So far it going fine.Only problems so far are the manifolds are totally different and can't swap them over,unless someone has a port stretcher. So I guess I have to use the intake and exhaust from the paseo,are there any vacuum tricks or wiring fixes I should be aware of?I have 4 days left on my vacation to finish it along with getting it ready for a sticker.Any help would be greatly appreciated
WanderR is offline   Reply With Quote
Old 06-28-2005, 12:25 PM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285880
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
repost this in hardcore......I tnk you're answer...or informed quote is there
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 07-02-2005, 02:28 PM   #3 (permalink)
View jeffs94's Photo Gallery
You will need to use the 5e intake but you may have to use the 3e throttle body or atleast use the TPS from the 3e. If the 5e, from the paseo, uses a distirbutor then most of it is plug and play. If it has the DIS, then you may have some troubles.....
jeffs94 is offline   Reply With Quote
