Ah yes, finally I can help someone with the same problem I had. I had that problem, I cleaned every vacuum, checked everything, it took me forever to figure it out.....
There is a metal line that runs from the EGR valve to the intake manifold....where it bolts to the intake manifold, that port gets clogged almost totally shut because of the PCV system dumping oil in it. Remove that line, and you'll also have to remove the throttle body to get to the port in the intake manifold...get some pipe cleaners and a screwdriver, anything you can get in there, I used an allen wrench, and ream the hole clean, and clean with some carb cleaner(2+2)...
More than likely that's the problem. I had checked the EGR valve, cleaned it, enlarged the hole of the EGR valve, cleaned the pipe, cleaned all vacuums, tested the vacuum switching valve, and the ciruit going to it, tested the vacuum modulator, and cleaned the port in the head to the EGR,...........all this before i figured it out. Also check out my tutorial on it...
http://board.tercelonline.com/viewthread.php?tid=19633
