I finally hit 100,000 miles on my 94 Paseo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2005, 09:40 PM   #1 (permalink)
View MrPaseo's Photo Gallery
Any suggestions as to what maintenaance I should get done to it?
Stick shift, 1994, what else do you need?
Thanks,
MrPaseo
MrPaseo is offline   Reply With Quote
Old 07-19-2005, 09:43 PM   #2 (permalink)
Allow me to add, I have not had anything changed, still same timing belt (It has one right?) and same water pump...
Only thing I've done to the car is had the oil changed every 3000 miles or so and had the radiator flushed...oh and the tires changed out twice
Old 07-20-2005, 05:44 PM   #3 (permalink)
Not Crazy
Paseorod's Avatar
View Paseorod's Photo Gallery
Timing belt sure, prolly around 60 000 miles,
your engine must be nice after all those oil changes
-Chris
Originally Posted by Dr Tweak
No, he's just being a dumbass
Originally Posted by sancho_153
well thanx everyone for being dicks...wait just paseorod...
Paseorod is offline   Reply With Quote
Old 07-20-2005, 06:36 PM   #4 (permalink)
View dexter_5000's Photo Gallery
do that and the water pump is worth doing even though its external. you wanna think about new drum brakes too.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 08-19-2005, 05:03 PM   #5 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
Rear wheel bearings, the ones for the brakes and the axle itself. Toyota recommends it done around 100K. Lube the chassis and check your bushings. Also check your upper shock and strut mounts.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
