95 tercel front axle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-09-2005, 05:28 PM   #1 (permalink)
View Sheila's Photo Gallery
I need to replace the front passenger side axle. Can anyone tell me if it is a hrad thing to do? Should i take it to a garage? The garage quoted me 153.00 plus tax..
Sheila is offline   Reply With Quote
Old 08-09-2005, 05:35 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Is that parts and labor?
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 08-11-2005, 12:05 PM   #3 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
I did both of mine for less than that. Go to autozone and get the axle. The ones i got are lifetime warranty and were not that expensive. I ve had them in for over 5000 mile and no problems. Its really easy to do them your self too. If you need help just ask.
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 08-12-2005, 03:45 PM   #4 (permalink)
Yes that is parts and labor, but only for 1 side. I am a mechanic but have never put an axle in a front wheel drive. I keep hearing horror stories.
Old 08-12-2005, 09:53 PM   #5 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
It is not dificult if you are a mechanic and have all the right tools, ie: tie rod end puller, 1/2" impact wrench or a big breaker bar, torque wrench, a slide hammer with some way to grip the shaft would be good too. Just get a shop manual and follow the steps and you will be alright.
The most difficult part is trying to loosen or tighten the axle nut if you don't have an impact wrench. Then you will need someone to press the brake pedal for you while you apply the breaker bar to the nut.
Good luck.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 08-12-2005, 10:46 PM   #6 (permalink)
View jeffs94's Photo Gallery
If you dont have a ball joint puller, then just unbolt the lower ball joint from the lower control arm.......pretty simple job.
jeffs94 is offline   Reply With Quote
Old 08-13-2005, 12:42 PM   #7 (permalink)
You ever try and get a shop manual for an 85 Tercell? They don't exist, you can't even order one, that is why I am not real game about doing it. i have nothing to go by.
Old 08-13-2005, 12:48 PM   #8 (permalink)
Have you checked ebay? Sometimes they're listed on there and you may even find a genuine toyota service manual.
Old 08-13-2005, 12:48 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
95 or 85?
雄のハヤブサ
Old 08-13-2005, 02:16 PM   #10 (permalink)
Donald's Avatar
Try Books4cars.com
Old 08-14-2005, 04:03 PM   #11 (permalink)
It's a 95 tercell. Unfortunately i do have the owners manual, but you cannot get a Chiltons or a Haynes. For some reason that was a "switching" year where they changed a lot of things mid year. I thought I could order one or find one on E-bay, but no luck. The owners manual is no help with mechanics.
Old 08-14-2005, 06:01 PM   #12 (permalink)
N/A bites
Tercel GTS's Avatar
You don't have to remove the factory wheels, just pop off the plastic center and you'll see a large cotter pin and nut. Remove those, then remove the lower ball joint from the lower control arm. Should be 2 bolts and 1 nut per side on the control arm/ball joint. Pull the wheel outwards and rearwards as you push the axle from center of wheel. Tie Wheel back out of the way(bungee). Pry axle from transmission. Align new axle straigh as possible, hold pressure inwards and pop in with hammer. Slide end back into wheel center and reattach ball joint, then axle nut. Check diff oil and refill.
Pop lil hubcap back on wheel. Go test drive.
I can do both sides on a rack in under an hour.
ps, it's made EXACTLY like a 91-94 in that section.
雄のハヤブサ
