help with cd player - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2005, 10:20 PM   #1 (permalink)
View bobbyg1243's Photo Gallery
USA help with cd player
ok i saw another thread about this but it didnt help me...i hooked up my cd player in my car..its a 92 tercel and i have the wiring harness....but when i hook the yellow memory wire up to the main power dont have memory...i tried everything and im getting sick of adjusting everything when i start the car up. anybody help me?
bobbyg1243 is offline   Reply With Quote
Old 08-11-2005, 10:32 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
is there power going into that wire? get a tester and test it
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-11-2005, 10:44 PM   #3 (permalink)
ill check it tomorrow but what if there is no power? am i screed or is there a way to run your own wire?
Old 08-12-2005, 12:24 AM   #4 (permalink)
View thoughthard's Photo Gallery
Main power? Isn't that a switched power source?
Maybe a blue with yellow stripe wire is a constant. Look for that, maybe?
http://installdr.com/Harnesses/Toyota-Wiring.pdf
thoughthard is offline   Reply With Quote
Old 08-12-2005, 12:34 AM   #5 (permalink)
Ninja-rator
i agree with thoughthard....look for that wire...the yellow constant battery 12v.
if you find no power...i guess...just try to follow the wire to where it 's not hooked and fix it there. If not it's as simple as finding another constant source of power.
Old 08-12-2005, 01:19 AM   #6 (permalink)
well the yellow wire is the 12v battery/memory so it must have power if it runs the 12v so thats why im confused on the wiring.
Old 08-12-2005, 01:21 AM   #7 (permalink)
Ninja-rator
yes, and that's why you should see if does have power by testing it
Old 08-12-2005, 01:46 AM   #8 (permalink)
Turn that shit up!
McTimson's Avatar
View McTimson's Photo Gallery
Blue with yellow stripe should be the constant 12v...check the fuse if there's no power coming from that wire. If you have a voltmeter, try to test that wire using a metal part of the car as a ground, or use a DC test light or something.
McTimson is offline   Reply With Quote
Old 08-14-2005, 12:23 AM   #9 (permalink)
91 tercel
View dillnu's Photo Gallery
wiring
run a hot wire strait from the battery with the proper fuse and connect the main 12v source and the memory power to just don't leave it on when you get out
dillnu is offline   Reply With Quote
Old 08-18-2005, 10:28 PM   #10 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
it's a 3-wire power supply to the head unit rught?
one to a constant 12V supply, one to ur accessory switch and one to ground?
nothing wrong with running a (fused of course) hot wire from ur battery's +ve pole and hooking up the other two wires as normal....just use as little wire as possible between the battery pole and the fuse
Hook is offline   Reply With Quote
Old 08-19-2005, 05:25 PM   #11 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
First of all, we need to determine if your trouble is with the Toyota wires or the radio wires. We need to do that first before we tell him a color to look for. If you start throwing colors out there without that info you will confuse the poor guy. Tell us if you need help on the car side or radio side and then we can help from there.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 08-21-2005, 10:35 AM   #12 (permalink)
well its on the car side..i have the harness...but i still havent checked the wire for power yet iv been too busy but its def the wire on the car.
Old 08-22-2005, 06:46 AM   #13 (permalink)
Got a FC3S!
Paseo15psi's Avatar
I'll check when I go to work today and tell you when I get home at around 11pm EST.
Old 08-23-2005, 06:17 PM   #14 (permalink)
ok sounds good thanks man
Old 08-23-2005, 06:54 PM   #15 (permalink)
Got a FC3S!
Paseo15psi's Avatar
+12 blue/yellow
switched 12 gray
ground brown
I hope that helps.
