96' Temp Gauge Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2005, 06:55 PM   #1 (permalink)
View 96GreenT's Photo Gallery
Question 96' Temp Gauge Problems
Hi, I have a 96' Tercel, and my Temp gauge does not move at all ...What could be wrong?
Check the Radiator , cap > Both OK warm not very hot.
Could it be the Coolant Sensor, or the Thermostat being stuck? Anyone had this problem.
What would be the process of elimination???
Any Help would great.
96GreenT is offline   Reply With Quote
Old 08-12-2005, 07:29 PM   #2 (permalink)
The Matrix has you......
View matrix37495's Photo Gallery
I had that prblem in my 93'. All i did was change the thermostat( about $9, i think) and that fixed it. I think someone put the wrong one in before and i had no heat so i changed it, and that fixed it.
Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body; but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "Wow ---- What a ride!!!"
matrix37495 is offline   Reply With Quote
Old 08-12-2005, 10:39 PM   #3 (permalink)
View jeffs94's Photo Gallery
Check the connector at the sensor and see if there is anykind of corrosion. Have you OHM'd the sensor?
jeffs94 is offline   Reply With Quote
Old 08-15-2005, 08:48 PM   #4 (permalink)
View NickR's Photo Gallery
If you are driving in Southern California in the summer, the engine ought to warm up to normal operating temperature even if the thermostat were stuck open (though it would take longer to reach normal operating temperature, maybe about 20 minutes?).
The temp gauge on my daughter's 92 Tercel stops working intermittently, and the cause turned out to be a poor connection to the temp sensor, as Jeffs94 suggested.
NickR is offline   Reply With Quote
