Idle control - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2005, 01:47 AM   #1 (permalink)
View tym1200's Photo Gallery
Exclamation Idle control
Another question... I searched the forum and couldn't find any other info on this. my car is idling way too fast and I need to know where the idle control thing is so I can clean it or get a new one, im just not sure what it looks like or where it is at on this car. Or do you think it could be a vaccum hose, I quickly looked and didnt see any that were off, but maybe there is one i actually need to look for
tym1200 is offline   Reply With Quote
Old 08-19-2005, 05:22 PM   #2 (permalink)
Got a FC3S!
Paseo15psi's Avatar
View Paseo15psi's Photo Gallery
There is a black rubber insert just left of the inlet on the throttle body. There is a set screw in there. Adjust that screw and then see is it works itself back loose. If it does, go get a new one from Toyota. It is cheap and should fix your problem. Take in consideration that my experience is from the 5efe,5efhe, and 4efte engines. A 3e may be a bit different.
Paseo Performance Information PM me if you need me...
Paseo15psi is offline   Reply With Quote
Old 08-20-2005, 12:20 PM   #3 (permalink)
The Cellist
View shogun6684's Photo Gallery
The screw can work its way back loose if the O-Ring on it goes bad, that's my experience with it. So pull it out and put a new one on.
shogun6684 is offline   Reply With Quote
Old 08-20-2005, 04:02 PM   #4 (permalink)
Is there a cap i need to take off of it first, or am i looking in the wrong spot
Old 08-20-2005, 10:42 PM   #5 (permalink)
Got a FC3S!
Paseo15psi's Avatar
There is a small plastic cap covering it.
Old 08-22-2005, 04:29 PM   #6 (permalink)
about the size of a quarter?
Old 08-22-2005, 10:01 PM   #7 (permalink)
Got a FC3S!
Paseo15psi's Avatar
On my Paseo it is smaller then a dime, not 100% sure on the Terc.
