1. got two questions, i got my 95 toyota t100 dx this august, when first purchasing it he did mention it had a slight oil leak but it a first car to im not to bothered, but i was wondering what would cause an oil leak right after oil pan and right before the transmission? i cleaned the pcv valve and that seemed to lessen the leak but it is still there any ideas where this leak could be coming from and how to fix it?
2. i have been noticing some leaking coming from my rear axle, i assume it is differential fluid, i went underneath my truck and started turning the drive shaft closest to the rear axle it seemed to move on it own just slightly, could this be a broken drive shaft joint?, any suggestions on what would cause this and if so how to fix it. is there an OEM part for this if this is the case or will a universal joint work?
-Thanks :grin:
-Thanks :grin:
