Like the tittle says im running out of ideas. driver side window hasn't worked for about a week. thought it was a bad motor. ordered a new one from oreily. hooked the new one up only to find out that it turned for a split second then wouldn't move. it will do this every once in a while, just move for a half second then stop. So then i thought well hey the switch must be bad, so i ordered a new switch on ebay. put the new switch in and tested it on the passenger side (passenger side works fine with the new switch) then tried it on driver side (same thing) it moved for a second then stopped. i'm thinking about cutting the connector plug out that goes upto the motor and wiring it directly tomorrow in case that is the culprit (it connects but doesn't lock in place) if that doesn't fix it then sh!t i'm out of ideas. Any help is appreciated :help:
Check the harness where it passes from the body to the door, sometimes wires break from flexing after years of use. You may need to pull the rubber boot out of the way completely to get a good look, sometimes the wire is broke inside the insulation and it's hard to tell.
Thanks for the ideas I checked the new motor I got from oreileys by putting it directly to the battey and it didn't move. Thanks to oreillys for selling me a $150 broken motor. Come to figure out I was the switch that was broken because when I put the old motor back in it worked done with the new switch! Problem solved! But ya not gonna be buying from Oreilly any time soon!!
It helps to apply 12V straight to motor and see if it moves;
Use the switch from the side opposite & check;
Visually inspect the connectors for pushed back pins etc.
All that stuff is applicable to all those applications that ran by switches in the inner door (i.e power mirrors, door locks, power windows)
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
588.4K members
Since 2001
