Can't get my key into the driver side lock - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
 5Likes
post #16 of 33 Old 02-06-2017, 10:10 AM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 464 Post(s)
beerhunt likes this.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline
post #17 of 33 Old 02-06-2017, 10:14 AM
BamZipPow's Avatar
Quoted: 464 Post(s)
post #18 of 33 Old 02-06-2017, 11:54 AM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
Hey thanks for the replies. I'll probably see if the locksmith can rebuild it'. I just need to get the window crank off and I just got the tool so I will see if that works. And so when I get the door panel off how do I fix the linkage to make sure the internal locking lever works? And most locksmiths say they won't do the Cars. Will they do it if I give it to them?
T-Bird100 is offline
post #19 of 33 Old 02-06-2017, 12:38 PM
BamZipPow's Avatar
Quoted: 464 Post(s)
If the locksmiths won't work on a car lock, then giving them the tumbler won't change their minds.
Did you watch any of the videos? You can see how easy it is fer you to work on the tumbler yerself. If anything, you could just as easily swap out the passenger tumbler with the driver side tumbler.
post #20 of 33 Old 02-06-2017, 12:51 PM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
Originally Posted by SC T100 View Post
Yes, it should...I think I mistakenly thought it wouldn't work in the passenger door, too. Just something else to check. But I agree...it sounds like the door lock linkage is jammed/bent/disconnected.
Well the linkage works when I move the rod it just doesn't work on the outside lock because the tumbler is seized. And the inside locking mechanism doesn't have a long enough stroke
post #21 of 33 Old 02-06-2017, 12:52 PM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
I haven't yet but I'll look after work. I also Still need to get the tumbler out of the car...
post #22 of 33 Old 02-12-2017, 08:07 PM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
So I bought some of the pb dry graphite lubricant spray and as I went to take the tumbler apart I sprayed it and worked it a bit and it actually freed up. It still catches when unlocking it but I just cycle it back and forth once and then it goes. As far as the interior lock mechanism what is the best way to adjust that?
post #23 of 33 Old 02-12-2017, 08:13 PM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
So I have just read that I should use brake cleaner and then the graphite. Should I re clean my lock since I had put wd40 and grease in already?
Update I went ahead and did this already to make sure the lock was clean.
Still trying to figure out the Best way to adjust the interior locking mechanism.
post #24 of 33 Old 02-15-2017, 03:09 PM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
Bump looking how to fix the inside lock. I was told the it may be the plastic pieces that connect the two rods together. Where can I buy one of these?
Is this what I need?
https://www.amazon.com/gp/aw/d/B00R2...ppL&ref=plSrch
post #25 of 33 Old 02-16-2017, 07:14 AM
Senior TN Member
SC T100's Avatar
Quoted: 97 Post(s)
Have you pulled the door panel yet to inspect the linkages?
'97 Extra Cab 3.4 4x4 5sp 102K and counting...
Aisin hubs, Marlin shifter bushings, a few fellow TN member mods, and lots of elbow grease.
SC T100 is offline
post #26 of 33 Old 02-16-2017, 11:51 AM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
Yes I did and when the lock button is flipped the rod doesn't travel far enough to to fully rotate the actual locking rod connected to door latch itself. The locking part itself won't actually fully rotate unless I take the rod connected to the latch and push it into its lock position. Then the interior lock lever will move to its final position. Is this a problem with the latch assembly or locking lever.
Basically to summarise the internal lock lever doesn't travel far enough.
post #27 of 33 Old 02-16-2017, 10:48 PM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
So I just ended up bending the connecting rod to the latch and that took up the extra slack so the lever now locks. See thee after photo below
The Following 2 Users Say Thank You to T-Bird100 For This Useful Post:
BamZipPow (02-17-2017), SC T100 (02-17-2017)
post #28 of 33 Old 02-17-2017, 01:24 AM
BamZipPow's Avatar
Quoted: 464 Post(s)
Maybe someone tried to slim jim the lock before and messed up the linkage?
BTW, the clear plastic that was over the door is both a vapor and noise barrier.
post #29 of 33 Old 02-17-2017, 09:01 AM Thread Starter
Quoted: 33 Post(s)
(Thread Starter)
So you are saying I should replace it? I just had that window replaced and they may have cut it. What should I use to cover it? Anything special or Just visqueen?
And where does it go over or under the connecting rods?
Also I think the rod looked stock but the latch mechanism had a lot of play in it so I just took up that slack with the rod.
post #30 of 33 Old 02-17-2017, 12:03 PM
Quoted: 4 Post(s)
Heavy Duty trash bag or any thick plastic.
F1
F1FANSF1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
Back
