Can't get my key into the driver side lock - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
 5Likes
post #1 of 33 Old 02-02-2017, 06:34 PM Thread Starter
Quoted: 36 Post(s)
(Thread Starter)
Hey everyone just a few days ago I went to put my key to unlock my driver door and it doesn't go all the way in. I tried wd40 and pb blaster yo no avail.
Update: the lock inside doesn't work. The door won't lock at all. When locked from inside it makes a different noise but still opens
Any ideas
T-Bird100 is offline
post #2 of 33 Old 02-02-2017, 07:32 PM
sdspeed's Avatar
Quoted: 187 Post(s)
I can lock and unlock the door from the inside.
Any ideas
Wow! I just started having the same issues, mine will go in but won't turn .
Using my back-up key has helped where it works "most" the time but something is failing.
sdspeed is online now
post #3 of 33 Old 02-02-2017, 08:57 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 296 Post(s)
If it doesn't work from either side, then maybe something's wrong withe the internal linkages.
It's thin metal rods and plastic clamps that can disintegrate.
Take the inside door panel off and check.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
The Following 3 Users Say Thank You to fourwd1 For This Useful Post:
BamZipPow (02-03-2017), SC T100 (02-03-2017), sdspeed (02-02-2017)
post #4 of 33 Old 02-03-2017, 01:51 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 484 Post(s)
Wink
With both the outside lock and internal locking mechanism not working, it would appear yer locking mechanicals on the door latch may be bonkers. You can do a few tests to figure out where the issue lies.
With the door panel off, disconnect the linkage to the key locking tumbler. Test to see if yer key will turn the tumbler completely left and right. If so, it's not the tumbler. See if you can cycle the locking mechanism by pushing down/pulling up on the connecting rod. I will have to take my door panel off later today and see where the possible issue could be that might be causing yer locking issue.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is online now
post #5 of 33 Old 02-03-2017, 06:18 PM Thread Starter
Quoted: 36 Post(s)
(Thread Starter)
Okay so I didn't get my door panel off because I didn't want to ruin it because o didn't know how to remove the window lever. but I reached and pushed the metal rod and I could lock the door. The internal locking mechanism was very close.
I still can't turn the key in the lock however. I also accidentally used white lithium grease spray instead of pb blaster. Is that going to be an issue
post #6 of 33 Old 02-04-2017, 08:55 AM Thread Starter
Quoted: 36 Post(s)
(Thread Starter)
How do I get this off??
post #7 of 33 Old 02-04-2017, 09:13 AM
Quoted: 4 Post(s)
You should be able to find one of these at a automotive store. If you push back the door skin(panel) you will see a "C" clip that holds the handle on. Use this tool to push the clip back, be careful sometimes they go flying off.
F1
Click image for larger version
beerhunt likes this.
F1FANSF1 is offline
The Following 2 Users Say Thank You to F1FANSF1 For This Useful Post:
SC T100 (02-06-2017), T-Bird100 (02-04-2017)
post #8 of 33 Old 02-04-2017, 02:07 PM Thread Starter
Quoted: 36 Post(s)
(Thread Starter)
Also how do i adjust the internal locking mechanism as it doesn't move the rod far enough to lock?
And the tumbler is the issue. What are my options?
post #9 of 33 Old 02-04-2017, 02:57 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 296 Post(s)
F1
Yes, They go flying everywhere.
Then it's hours wasted looking for it.
I know.
89 4Runner - stock
fourwd1 is offline
post #10 of 33 Old 02-06-2017, 08:03 AM
Senior TN Member
SC T100's Avatar
Quoted: 97 Post(s)
Ok quick question. Are you sure it's not a too-worn key? Do you have a spare key that hasn't been used much? I had issues with a worn key a while back...swapped to a newer cut key and it fixed my issues. You could also have a new key ordered from the dealer.
'97 Extra Cab 3.4 4x4 5sp 102K and counting...
Aisin hubs, Marlin shifter bushings, a few fellow TN member mods, and lots of elbow grease.
SC T100 is offline
post #11 of 33 Old 02-06-2017, 09:33 AM Thread Starter
Quoted: 36 Post(s)
(Thread Starter)
I haven't but the key works in the other key lock. Wouldn't that tell me it was a key issue?
post #12 of 33 Old 02-06-2017, 09:49 AM
BamZipPow's Avatar
Quoted: 484 Post(s)
You should be able to take yer tumbler to a locksmith and have them rebuild the tumbler. You can do it yerself if you can git the internal parts. There are a few threads on the internet to show you how to do it and where you can git the parts. I'm not sure if you can swap the passenger side with the driver side but it might be worth a shot.
http://www.toyotanation.com/forum/10...-cylinder.html
BTW, that window crank handle isn't OEM but I guess you can figure that out if yer passenger side is different.
post #13 of 33 Old 02-06-2017, 09:58 AM
Senior TN Member
SC T100's Avatar
Quoted: 97 Post(s)
Yes, it should...I think I mistakenly thought it wouldn't work in the passenger door, too. Just something else to check. But I agree...it sounds like the door lock linkage is jammed/bent/disconnected.
SC T100 is offline
post #14 of 33 Old 02-06-2017, 10:00 AM
BamZipPow's Avatar
Quoted: 484 Post(s)
http://broadwaylockandkey.com/toyota/
post #15 of 33 Old 02-06-2017, 10:03 AM
BamZipPow's Avatar
Quoted: 484 Post(s)
You can also go to the dealership with yer VIN and/or proof of yer vehicle to have them code cut you a brand new key. Should cost around $10 or so. Some locksmiths can do this service as well.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
Back
