T100 Park Issue - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
 2Likes
  • 1 Post By BamZipPow
post #1 of 12 Old 05-15-2017, 05:20 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
T100 Park Issue
I've recently acquired a 1996 4x4 T100 auto 3.4 from my parents. It only has 148,800 miles on it and pretty clean nice truck for its age. It does have a few quirks and I was hoping I could get some answers from someone. Sometimes when you put it in park and get out, it keeps rolling. I make it a habit to engage the parking brake when I get out because I don't want it to keep rolling. I did a quick search and didn't find anything. I was wondering if anyone else has experienced this. Also, it doesn't have power windows/locks and I would at least like a power locks. It makes things easier with kids. Has anyone done a power lock install write-up? Thanks in advance for any replies!
David
MDOC111 is offline
post #2 of 12 Old 05-15-2017, 06:21 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 463 Post(s)
Welcome to the forums!
Does the shifter lock in Park? Does the gear indicator show that it is in Park? If not, then yer shifter might need to be adjusted. You can find the adjuster in the engine bay.
Post up some piccies of yer T-100!
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline
post #3 of 12 Old 05-15-2017, 06:28 PM
BamZipPow's Avatar
Quoted: 463 Post(s)
As far as power locks go, you'll need some actuators like these fer about $8 each plus shipping.
http://www.solidsignal.com/pview.asp?p=CS-610-S1
beerhunt likes this.
post #4 of 12 Old 05-15-2017, 06:30 PM
BamZipPow's Avatar
Quoted: 463 Post(s)
Wink
All Electronics has the acutator fer $5.50 each plus shipping.
http://www.allelectronics.com/item/d...ctuator/1.html
post #5 of 12 Old 05-15-2017, 06:42 PM
BamZipPow's Avatar
Quoted: 463 Post(s)
Wink
Here's a 4 actuator kit and controller fer about $30 shipped from Amazon.
https://www.amazon.com/POWER-DOOR-LO.../dp/B0002KR9Q6
post #6 of 12 Old 05-15-2017, 08:07 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Wow, thanks for the quick replies! Yes, it shows its in park but when you let off the brake it will keep rolling. It doesn't do it all the time just occasional. My parents told me that it would do it, but I just figured they were doing something wrong. It rolled about 2-3 feet this afternoon when I was getting out before I was able to get it stopped. I will check out those actuators. Thanks again!
MDOC111 is offline
post #7 of 12 Old 05-15-2017, 11:38 PM
BamZipPow's Avatar
Quoted: 463 Post(s)
Wink
Could you snap a piccie of yer engine bay...in particular of the shifter linkage near the brake booster? Thanks!
I think you can adjust the linkage a little and it should allow the parking pawl to engage in the transmission.
post #8 of 12 Old 05-18-2017, 04:39 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Sorry for the delay, its been crazy at work this week!
MDOC111 is offline
The Following User Says Thank You to MDOC111 For This Useful Post:
BamZipPow (05-18-2017)
post #9 of 12 Old 05-18-2017, 07:11 PM
BamZipPow's Avatar
Quoted: 463 Post(s)
Here's what it looks like on mine.
Could you git a shot similar to mine? I can't see how much adjustment you have on yer linkage with that hose in the way. Thanks!
post #10 of 12 Old 05-18-2017, 08:16 PM
Senior TN Member
Quoted: 315 Post(s)
Originally Posted by MDOC111 View Post
I've recently acquired a 1996 4x4 T100 auto 3.4. it doesn't have power windows/locks and I would at least like a power locks. It makes things easier with kids.
FWIW..I added elect. door locks loooong ago on old ride I had, BUT wasn't toyo truck. Got um at..JC Whitney 'electric door locks kit". Look around u may find what your looking for ?
FYI..if your handy with tools & have some practical DIY knowledge will help. Gotta remove door panels..cut out for switches..run wires & elect. hookup to batt or other 12V source. Good luck.
2014 HL Blizzard Pearl XLE AWD V6 Ash Int. M. Latitude Tour 245/60R18. OEM Tow hitch/4 pin. B/D 04/14
BUFFO is offline
post #11 of 12 Old 05-19-2017, 01:08 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Here is what mine looks like. I'm still learning the picture posting!
MDOC111 is offline
BamZipPow (05-19-2017)
post #12 of 12 Old 05-19-2017, 03:30 PM
BamZipPow's Avatar
Quoted: 463 Post(s)
Looks like you have enough to work with fer adjustment. You want to do a few 1/2 turns at a time. The bottom nut needs to be loosened and the the top nut gits tightened. Test to see if the parking pawl will engage. Repeat as necessary.
Hopefully the pawl isn't worn down or broken.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
Back
