Battery low after leaving the flashers on for a few mi - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
post #1 of 2 Old 06-18-2017, 08:38 AM Thread Starter
Senior TN Member
Quoted: 260 Post(s)
(Thread Starter)
Wasnt do this before when i had the battery changed less than a year ago. Went to the same place to have my battery tested and it tested out good. Went to the other battery place and found out the neg cable was loose so i replaced the clamp but still have the same issue. I bought my battery from interstates batteries but its like the refurbished ones for like 25 30 bucks. But i wanna now why or whats causing my battery to drain the quickly with the truck off. Battery maybe?
Sent from my LGMS631 using Tapatalk
kobej05 is offline
post #2 of 2 Old 06-18-2017, 02:49 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 484 Post(s)
Wink
When they tested yer battery, they should've given you a print out or told you what the battery life was.
With a bad battery ground connection, yer battery wouldn't have had a decent charge circuit to work with. Now that the ground cable is secured, you should be able to charge yer battery back up to snuff.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
Back
