PO770 and PO773 engine code - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
post #1 of 7 Old 12-23-2008, 08:46 PM Thread Starter
1998 4WD T100 Owner
Quoted: 0 Post(s)
(Thread Starter)
My 98 T100 4WD has a check engine light on and showing codes P0770 and P0773 (shift solenoid E malfunction and shift solenoid E electrical respectively). I would love to solve this without paying the $950 the dealership is quoting. I'm happy to replace the solenoid myself if that's what needs to happen.
I have a Haynes Repair Manual and can easily remove the transmission pan. However, I can't find anything on where the shift solenoid E is located. Are there several solenoids under the pan? Which is which? Will replacing the solenoid solve the problem? Should I be testing something else?
Any help would be deeply appreciated. Pics would be awesome.
Jim
jbartoo is offline
post #2 of 7 Old 12-23-2008, 09:37 PM
just a nobody
Quoted: 118 Post(s)
Don't know if this will help you or confuse you: http://www.*******.com/fsm/2000/Serv...id%20Ident.pdf. I believe the solenoid that you are look for is 'Shift Solenoid Valve SL'.
I would suggest doing some testing first for the code, like check the solenoid resistance to ground, and signal from the ECM to enable the solenoid. Because you problem may also be internal hydraulic problem too.
N.E.O.
new echo owner is offline
post #3 of 7 Old 12-23-2008, 10:14 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 328 Post(s)
Are you sure the wiring harness is good? Check it over carefully...it's worth it's weight in gold.
Looks like those solenoids are going over $200 each...
BamZipPow is offline
post #4 of 7 Old 12-24-2008, 11:57 AM Thread Starter
1998 4WD T100 Owner
Quoted: 0 Post(s)
(Thread Starter)
Thanks N.E.O and BZP. This document is just what I'm looking for. I'll do some more testing.
jbartoo
jbartoo is offline
post #5 of 7 Old 01-17-2009, 12:02 PM Thread Starter
1998 4WD T100 Owner
Quoted: 0 Post(s)
(Thread Starter)
I just want to thank both N.E.O and BZP for their help with my T100 problem. I ended up removing the shift solenoid SL and testing it. Sure enough, it was showing a lower than normal resistance. The new solenoid (sold only throught the dealership) was $275. Replaced on Dec. 30, 2008 and haven't seen an engine light since.
jbartoo is offline
post #6 of 7 Old 07-28-2010, 02:11 PM
jc12898's Avatar
Quoted: 0 Post(s)
I know this is an old thread but does any one have any info on how exactly to test the wire harness and solenoid ? I also have a 98 T with the same codes showing up and want get some info to see if it is something I can repair myself thanks in advance
jc12898 is offline
post #7 of 7 Old 07-28-2010, 07:05 PM
BamZipPow's Avatar
Quoted: 328 Post(s)
Wink
You would need to check each wire to/from the trans to the ECU using a multimeter and some extra wire.
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
ę Back
