Loose Passenger Door - Toyota Nation Forum : Toyota Car and Truck Forums
T-100 Forum Discussion forum for the short-lived but extremely popular Toyota T-100 model.
 2Likes
post #1 of 31 Old 04-25-2012, 11:33 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The passenger door on my T100 does not seem to close tightly; however, I see no features to tighten up the latch. Suggestions?
Carl P. is offline
post #2 of 31 Old 04-25-2012, 12:01 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 328 Post(s)
Does the door latch still have the black plastic cover on it? Do a search fer door latch here in the forums...
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is online now
post #3 of 31 Old 04-25-2012, 02:29 PM
Quoted: 53 Post(s)
In all honesty it doesn't even matter if it does have part/all of the black plastic covering it - they still do not function properly with and the lack of adjustment on them just hinge (with pun) folks towards buying new.
Search "door lock actuator" here in the forums to find a decent attempt (poorly executed) pictorial on the install one of the members did.
I to replaced them in my T100 and although I had a really hard time swallowing the $150/each price for them, I ALWAYS smile inside everytime I open/close the door(s).
IE: they are worth it if you plan to keep the truck a while; it is always little things like this that make your rig feel "nice" if you know what I mean.
noahrexion is offline
post #4 of 31 Old 04-25-2012, 09:07 PM
Quoted: 0 Post(s)
You may try flipping the latch in the jamb 180. Two big phillips head screws are all you need to remove. Takes about 5 minutes and worth a shot
blandis is offline
post #5 of 31 Old 04-26-2012, 12:52 AM
Quoted: 4 Post(s)
I had the same problem and replaced the door seal for 120.00 from the dealer. Now its so tight i have to slam it to shut it.
roscodog01 is online now
post #6 of 31 Old 04-27-2012, 07:31 PM
Quoted: 0 Post(s)
I wrapped some duct tape around mine...a few wraps will do...strip it off and split into 1/4 inch wide strips...wrap it around the striker plate a little at a time until it stops....did mine about 4 month ago and I'm still happy. The price for the repair parts IMO is way out of line. I think they wanted around $150....for each door. Why so much...dealer Item of course!
'95 T-100 V6 4WD 5 Speed
'09 Camry LE I4/2.4L
"if it ain't broke fix it till it is"
skip4309 is offline
post #7 of 31 Old 05-04-2012, 01:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hmm...decided to crack open the repair manual. All you have to do is loosen the screws on the striker plate and tap it in a little. The holes must be slotted under the plate.
Carl P. is offline
post #8 of 31 Old 05-09-2012, 08:50 PM
Quoted: 5 Post(s)
Need to be more specific of the problem!
Try all of the above (except for the new seal) to adjust the door, if they all fail to fix your problem, look inside the door jamb and see if the actuator (the plate that locks onto the striker) is loose, or has any other malfunction (feel free to use any other car available for comparison as to how is supposed to work) in my case it would not retrieve that locking plate all the way back up, and sometimes it would hit the striker, and due to being loose it would not hold the door tight. That was my problem, and the only solution was a to buy new door lock assemblies and replace them.
Hint: you should not have to slam your door to get it to close tight, after replacing the door lock assemblies my doors close so smoothly just like any new car, I barely have to put any effort into closing it and it seals tight.
I don't know if the locking assemblies from any other toyotas might be compatible, but if you can and can afford to take yours out and go to the junk yard and compare it to other toyotas of similar years and who knows it might work.
1989SupraT is offline
post #9 of 31 Old 05-16-2012, 12:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Loose Door
I guess it helps to crack the maint manual...the striker plate is adjustable by just loosening the large phillips head screws.
Carl P. is offline
The Following User Says Thank You to Carl P. For This Useful Post:
1989SupraT (04-22-2014)
post #10 of 31 Old 05-20-2012, 03:02 PM
1/2 ton giant's Avatar
Quoted: 0 Post(s)
You door is not lose. I have had the same issue. What it is, is the door latch itself. These door latches were not the best to begin with. It is a very simple procedure to do. Just pull off the door panel (do not break the plastic screws, and you will need to reach in from behind to unhook the bar. I am doing mine here in a few weeks when i get some time off
1/2 ton giant is offline
post #11 of 31 Old 08-27-2012, 11:02 AM
crtfour's Avatar
Quoted: 0 Post(s)
I have (I think) the same problem on both doors. Do your door(s) tend to "rattle" when going over bumps and uneven pavement? On my truck even with the door closed and latched, I can still push on it and it moves a little.
crtfour is offline
post #12 of 31 Old 09-01-2012, 01:13 AM
Quoted: 0 Post(s)
just my left or passenger door. It is the latch itself. the mechanism has come slightly loose inside and there is no way to fix it unless you replace the mechanism itself.
post #13 of 31 Old 08-31-2013, 12:58 PM
Quoted: 17 Post(s)
Would like to try and adjust my hinges but need SST 09812-00010.
Anybody got any ideas on where to find one?
Okie-J is offline
post #14 of 31 Old 08-31-2013, 01:36 PM
Quoted: 17 Post(s)
Found it.
OTC Tools 0981200010 12MM Door Hinge Bolt Wrench
Okie-J is offline
The Following User Says Thank You to Okie-J For This Useful Post:
BamZipPow (08-31-2013)
post #15 of 31 Old 08-31-2013, 04:51 PM
BamZipPow's Avatar
Quoted: 328 Post(s)
Red face
Originally Posted by Okie-J View Post
Not sure if the 12mm wrenches listed below will be long enough to give you enough leverage to work with like the OTC tool will.
Sears sells a 5 piece "S" type of wrenches fer about $32.
http://www.sears.com/sunex-5-piece-s...46816?prdNo=32
$29...http://www.sears.com/sunex-tool-5-pi...45714?prdNo=38
Curved Design for Maximum Access in Confined Area
Includes Sizes: 8mm x 9mm, 12mm x 13mm, 14mm x 15mm, 16mm x 17mm, 18mm x 19mm
Harbor Freight's set fer $16...
http://www.harborfreight.com/5-piece...set-99699.html
10mm X 11mm, 12mm X 13mm, 14mm X 15mm, 16mm X 17mm, 18mm X 19mm
Length 5-1/2 in., 6-3/16 in., 7-1/2 in., 8-3/4 in., 9-1/4 in.
The Following User Says Thank You to BamZipPow For This Useful Post:
Okie-J (08-31-2013)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100 Forum
User Tag List
Linear Mode Linear Mode
Back
