Idles erratically stalls & hesitates - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 12-07-2006, 06:06 PM   #1 (permalink)
View bravo3's Photo Gallery
Sorry I dont know why this thread is on 4 times?? 1994 3.0 liter . no codes in ecm. complete tune up. & timing has been done. guys this is what I have done . New fuel pump and filter . New egr valve & cleaned vacuum modulator. cleaned & checked pcv valve . checked all vacuum hoses . checked cold start injector ohms ok . engine runs good cold and no skipping. thanks
bravo3 is offline   Reply With Quote
Old 02-24-2007, 10:39 PM   #2 (permalink)
View tr918's Photo Gallery
Having the same problem with a 1993 T100 3.0L. Did you ever find out what the problem was?
tr918 is offline   Reply With Quote
Old 02-24-2007, 10:54 PM   #3 (permalink)
View toyomoho's Photo Gallery
Might check the MAP or MAF sensor (which every one you have), or the IAC valve (adjusts idle). Owners of other Toyota models have been spraying Seafoam into the throttle body area (inside) to clean things out. But I have no idea about this engine.
Old 02-24-2007, 11:27 PM   #4 (permalink)
Thanks. Would the MAF and or the IAC cause a rich condition?
Old 02-25-2007, 12:12 AM   #5 (permalink)
Rich at idle or hwy speeds. The IAC uses a little bypass air to stabilize idle. My guess is this amount of air is irrelevant at high RPM. The MAF controls injector timing thus controls mixture. In theory if the MAF has a problem, the ECU will go into a fixed timing mode and allow the car to be driven.
I suggest if you are going to keep this truck to pickup some kind of maintenance info. All of the components can be tested and thus need not resort to an expensive swap out method. Also the ECU should monitor these systems, have you tried to pull up any codes. AutoZone is supposed to do this for free.
Most Toyota’s have some type of mixture enrichment system when the engine is cold. Either a cold start injector or something else. Sometimes these things fail in the on position. What model engine in this truck.
Old 02-28-2007, 12:37 PM   #6 (permalink)
Sorry I did not repost sooner. I had tested the IAC and MAF sensors. It ended up that the cold start injector was busted. When checked with an ohmmeter it checked fine. When the engine was running it continued to keep spitting fuel into the engine causing the rich/flooding condition.
Thanks to all,
-TR
Idles erratically stalls & hesitates bravo3 T-100 0 12-07-2006 06:06 PM
Idles erratically stalls & hesitates bravo3 T-100 0 12-07-2006 06:05 PM
Car starts and idles low or stalls immediately 97&02camryleI4 Camry & Solara Lounge 15 06-20-2005 05:08 PM
camry idles low and occasionally stalls!! stussy02 Camry & Solara Lounge 7 11-03-2004 02:37 PM
