trans fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > T-100
T-100 Discussion forum for the short-lived but extremely popular Toyota T-100 model.
Old 12-10-2006, 10:11 AM   #1 (permalink)
View casey Olney's Photo Gallery
trans fluid
in my Haynes manual it says i need to fill the trans up with 11 qts of fluid?
is this correct or did someone misprint?
thats alot of transmission fluid
anyone know if this this correct? (95 extra cab)
kc
casey Olney is offline   Reply With Quote
Old 12-10-2006, 02:50 PM   #2 (permalink)
View T100Kevin's Photo Gallery
I have a 95 T100 with V6. That 11 quarts you reference is total capacity. My owners manual say that for drain and refill - it should take 1.7 quarts.
I regularly drain and refill the trans fluid every 24K or so. I measure the amount drained so I know roughly what to put back. Usually about 2 quarts or so comes out.
Of course after refilling, you want to measure the fluid level with the dip stick. Be very careful not to overfill the trans - you can cause foaming and the like. The only way to get rid of all the fluid is with a power flush - done with a special machine at dealer or other shop.
T100Kevin is offline   Reply With Quote
1995 Camry losing Trans Fluid . kentarver 3rd & 4th Generation (1992–1996 & 1997–2001) 7 11-27-2006 01:24 PM
when to change trans. fluid chrisusvi Tercel, Paseo, Starlet, and Sera Forum 3 03-07-2006 06:14 PM
97 Tercel auto trans fluid capacities uptownwest Tercel, Paseo, Starlet, and Sera Forum 0 10-12-2005 01:40 PM
gen3 trans fluid change Q 95camguy 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-19-2005 06:16 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 02:19 AM
